Replacing 3-way dimmer switch
Old 02-05-09, 11:24 AM
Im trying to replace a diimmer switch. The switch in the box now has 2 Black
1 Red
1 Green (ground)
in the box there are 2 wires, 1 with 2 wires white and black
1 with 3 wires white,black,red
the way it is wired now
from 2 wires white to black on dimmer
black to 3 wire black
3 wire red to red on dimmer
white to black
black to 2 wire black
now the new dimmer I bought has wires, 2 red,1 black and green (ground)
Would l wire it as 2 reds on dimmer to whites and black to red?
Thanks for your time !
Old 02-05-09, 11:47 AM
pcboss's Avatar
Received 109 Votes on 95 Posts
You need to identify which wire in currently on the odd colored Common terminal on the 3w switch. This will connect to the Common wire on the dimmer. The other 2 wires can connect to the other wires on the dimmer.
Connect the grounding wire to either the grounding terminal or a ground wire on the dimmer.
Old 02-05-09, 01:30 PM
W
Received 1 Vote on 1 Post
I deleted the post, my fault for not reading it clearly.
