Another GFCI in series question
Old 02-07-09, 12:31 PM
So I have a 20amp circuit in my garage that I wired up last year. The first and second receptacles are GFCI ( I know better now - only needed one to start). Today, I went out to play in the shop and went to turn on the radio plugged into the SECOND GFCI - no power, I noticed that the FIRST receptacle had tripped. So I reset the first with no problem, but then went to reset the second - and it tripped the breaker on the first receptacle again. Its back and forth now. Could I have bad GFCI's? I'm inclined just to replace the second with a std 20a receptacle. I've doubled checked my wiring;
From sub-panel to LINE side on the first receptacle. Second wire from LOAD side of first receptacle to LINE side of second, and so on to other receptacles.
Thoughts? Advice?
Old 02-07-09, 01:46 PM
W
Received 1 Vote on 1 Post
All the GFI's need to be wired on the line side. Do not wire a downstream gfi from the load side of another.
Old 02-07-09, 03:55 PM
Thanks WN,
That was my problem. I'm not really sure if I crossed up the second one when I was checking to make sure the wires were tight or what, but the other outlets in the series were wired line side.
D'oh!
Old 02-07-09, 08:52 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If not GFCI they should be on the load side. Wasn't sure from your wording they were.
P.S. Series wiring is never use for receptacles. It is always parallel. What you really meant is sometimes called "daisy chained".
Old 02-08-09, 05:57 AM
W
Thanks for adding that part.
Old 02-08-09, 12:10 PM
ray/wn
Thanks for the clarification - yes they are wired in parallel - not series, my bad. Just to be sure I've got this correct (in case someone else is wiring a set out outlets with GFCI;
- From panel to LINE side of 1st GFCI.
- From LINE side of 1st GFCI to LINE side of 2nd GFCI.
- From 2nd GFCI to LOAD side of std 20Amp outlet (3rd in string). If this were another (3rd, why I wouldn't know) GFCI, it would be wired to the LINE side.
Is that correct? PS, the trhee outlets are the only thing on the circuit - no other branches.
Sorry for the confusing wordage above.
Old 02-08-09, 12:12 PM
W
You go it.
blah blah blah
Old 02-08-09, 12:57 PM
ray2047's Avatar
If you meant from load side of GFCI yes you have it.
Old 02-08-09, 01:41 PM
Cool - yep from LOAD side of 2nd GFCI to LOAD side of std 20 amp...
Thanks for the help ray/wn
Old 02-08-09, 02:28 PM
Although connecting a GFCI on the load side of another GFCI is not usually advised, it nevertheless works perfectly almost all the time. You may have a failing GFCI.
