Mid-run receptacle question
Old 02-08-09, 09:21 AM
I have run 12/2 for all my outlets. Should pig-tailing my mid-runs be the way to go. Seems this would be easier than the 4 connections for getting 12/2 into the standered box neatly, "I do add 2 wire nuts". Also, wouldn't this keep a good circuit if I lost a mid-run recept? Looking for opinions/ code problems since this involves 21 receptacles. Thanks
Old 02-08-09, 09:26 AM
Received 1 Vote on 1 Post
Either way is fine, whatever works for you.
Just don't use the backstab connections, although I think it won't accept a #12. (Never done it but I've "heard" it won't)Beer 4U2
Old 02-08-09, 09:49 AM
Using the four screws would be easier and faster than using wire nuts. Pigtailing has its devotees, but I personally wouldn't bother.
Old 02-08-09, 09:59 AM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
I would pigtail. That way you do not depend on the .50 cent device for your connections. If one goes bad or you have a bad connection it will be easier to find and you will not risk damage to equipment down the line.
Not that I use them, but no, the back stabs are not sized for #12
