GFCI outlets question
Long story short . . . Is it ok to have two GFCI's on the same circuit?
Short story long, I replaced an outlet in a bedroom that was falling out of the wall with a GFCI outlet. This outlet feeds one more outlet in the room. The wiring is fine and the downstream outlet trips when testing the GFCI.
Well, I didn't know that the beginning of the circuit is ACTUALLY in a bathroom that sits right before the bedroom.
So, I would like to install a GFCI outlet in the bathroom as well.
So, it would be:
Breaker box --> GFCI outlet --> GFCI outlet --> Protected outlet.
I would really like to avoid having the switch out the second GFCI outlet, but of course, I want to do things correctly.
I hope ya'll follow my question.
Thanks!
So, it would be:
Thanks!
Best to use only one GFCI. Will assume your current setup is grandfathered so wiring is OK as is but by latest national code bedroom can not be on bathroom circuit and must be protected by AFCI breaker. Why are you putting a GFCI in the bedroom?
I wanted to provide some additional protection in the bedoom because the outlets are not grounded & it is my 2 y/o's room.
If you just use the LOAD terminals in the bathroom GFI the bedroom one will be independant and will not see the other GFI.
I could but was trying to avoid switching out the GFCI that is currently in the bedroom.
