4 wire T-stat to 2 wire setup?
I'm interested in purchasing a programmable T-stat to reduce heating cost. I removed the old dial T-stat and revealed a two wire set-up. One, black and one white wire. Which is a 240 volt system. I have not pulled out the Volt meter just yet, so I can't be certain it's a 240v system just yet.
After looking around, I've only seen one T-stat out there that would be compatible with my system.(baseboard)
So my question is, being there are many 4 wire T-stats out there, can I use one of those for my 2 wire system?
Short answer, Yes, you can use a four wire stat with a 2 wire system. You just do not connect the other pole.
You need to check it with a meter. Since you only have two wires you may have a 120 volt heater.
I didn't mention gas furnaces. It controls electric baseboard heat.
If you only have a single black wire and a single white wire, then you have a 1-pole switch loop configuration. You can use any line-voltage programmable thermostat so long as it is self-powered with a battery. You cannot use many of the thermostats which require power from the line as you only have a partial circuit at the t-stat box.
Do you have more info? Are there more wires in the box?
IF you only have 2 wires (not cables) in the box, and you get 240 volts between them, this is not going to work. All the stat does is close the circuit like a switch. If you put those two wires, on a single pole in the stat, your stat will last about 1/186,000 second.
You have a 240V heater, which has power fed at the heater, and runs one pole of the circuit through the t-stat loop. As I said before, you need a 240V line-voltage one-pole or two-pole t-stat which does not require power from the circuit.
As you stated in your last post, one that is battery powered? I'm having a difficult time finding one online. Off hand do you know of a model and brand?
