Reload this Page >
Honeywell Baseboard Heater Programmable Thermostat Questions
Old 03-03-09, 10:03 AM
Hello, I'm considering purchasing a Honeywell LineVoltPro 8000 programmable thermostat for my baseboard heaters. It's received excellent reviews, however, I noticed that it's only rated to 15 amps, and my breaker is a 20 amp double pole.
Why on earth would they make a thermostat for baseboard heaters that's only rated for 15amps? Aren't most of these hooked up to 20 amp circuits? CAN it indeed be used with a 20 amp double pole? All of my heaters (4) add up to about 3000 watts, should I be using a 15 amp double pole breaker instead?
Here are the specs and a link to the thermostat:
Electrical Ratings - 15 Amps Max; 3600 Watts at 240 VAC, 3120 Watts at 208 VAC
Buy Honeywell Digital LineVoltPro™ 8000 Programmable Heat Only Thermostat | Honeywell TL8230A1003
Thanks in advance for your advice.
Old 03-03-09, 10:10 AM
Received 42 Votes on 40 Posts
Because 15A is adequate for most installations; 20A and 30A thermostats are substantially more expensive due to the heavy duty components.
Yes. Generally speaking the breaker matches the wire (#12 - 20A; #14 - 15A), and the switch matches the load. So you can have a switch which is rated less than the circuit as long as the switch is large enough to handle the load.
3000W / 240V = 12.5A
You could use a 15A breaker if you wanted to, or you can leave the 20A breaker assuming you installed #12 wire. The 15A thermostat is okay for your 12A load.
Old 03-03-09, 10:17 AM
Thanks for your reply ibpooks. Makes perfect sense.
I am using 12/2 wire. Thanks again for your time, much appreciated.
Aaron
