Dryer cord installation
Old 03-03-09, 01:49 PM
D
Smile Dryer cord installation
I have a Kenmore Electric Dryer that I need to install a plug on. It has a 3 prong style now for house use. I have moved to a mobile home now and it has a different style with maybe 4 prongs. Any instruction is greatly appreciated! I have installed plugs before but not this style. Thanks again
Old 03-03-09, 02:36 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You will need a four wire cord set. It is best to follow the manufactures instruction but in general on a three wire setup there is a bonding strap or wire between the metal case and the neutral connection. You remove that strap/wire and connect the green wire of the cord set to the case where the bonding strap was originally connected. Other connections are the same.
Old 03-03-09, 04:04 PM
D
Appreciate the information.
