20a GFCI???
Received 0 Votes
20a GFCI???
Two questions...
1) I have seen a few GFCI outlets at the store that say they're rated for 20a, but they do not have the t-shaped neutral slot. What is the purpose of this?
2) I have some left over 20a GFCI outlets that do have the t-shaped slot. Can I use these on a 15a/14ga circuit? I'm guessing the answer is NO!!!, but this is in my own house and I know I will never plug a 20a device in to them.
Thanks,
Rich
Thanks,
Rich
Two questions...
Thanks,
Rich
Thanks,
Rich
2. You are correct. "Can I use" is ambiguous. You may mean "Does code permit use of". All codes assume that you will either die or sell the place without any documentation of stuff you would never do.
Received 0 Votes
Ok, I figured I couldn't... or shouldn't use the 20a GFCI's on the 15a circuit. No problem there, I'll just get some new ones.
I'm still a little confused about the 20a GFCI outlets without the t-shaped neutral though. Do I understand that these can can provide 20a to downstream protected outlets, but the outlets on the actual GFCI are only good for 15a? If that's the case, why would you ever buy or install one of these instead of a true 20a GFCI w/ a t-shaped neutral?
Received 0 Votes
Originally Posted by ibpooks
You can't use the t-slot 20A recepts on a 15A circuit, but you can use 20A feed-through recepts on a 15A circuit as long as the recept does not have the t-slot.
The true 20A recepts are about $1.00 more expensive. Believe it or not some people are also incredibly picky about unimportant things and will complain about the t-slot looking different than the other recepts.
That would be correct. As long as there is more than 1 place to plug into the 15 amp receptacles can be used on a 20 amp circuit with #12 wire. This is why the ability to pass through is important.
Received 0 Votes
I'm not even sure they make GFCIs without a 20-amp pass-through. I think they all have this. In fact, I would venture to guess that all outlets of any kind (GFCI or not) sold today have at least 20 amp pass through.
