breakers
Old 03-11-09, 04:39 PM
breakers
hey all do i need a special type of GE 100 amp breaker to accept #2 wire , or do they all have large enough lugs ?
Old 03-11-09, 05:27 PM
It should have large enough lugs. Make sure of the cu / al rating though.
Old 03-11-09, 07:23 PM
what
what is the cu /al rating mean . what is the name for entrance cable 2 awg 3 conductors and 1 un insulated ?
Old 03-11-09, 07:37 PM
Received 42 Votes on 40 Posts
CU means the breaker is rated for use with copper wire, AL for aluminum wire. A 100A breaker should be able to accept #2. The wire you have is probably SER cable.
Old 03-11-09, 07:38 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
The breaker will have a mark or label that shows CU/AL meaning it is rated for copper and aluminum wire. CU will mean it is only rated for copper.
I think the cable your thinking of is SER 2-2-2-4
BAH! Too slow.
