breaker
Old 03-16-09, 06:34 AM
E
breaker
ok I have got 250' of #2 quad plex /polomino wire to go from my house to pole to pole next to my barn then to weather head on barn . to get inside each place, outside house into my 200 amp panel and from barn gable end to its new panel i was going to use ser 2-2-2-4 . ok total run from building to building is 200 ' . so my question is to use a 100 amp breaker comming out of my 200 panel should it be single or double pole and why ???
thanks
Old 03-16-09, 07:01 AM
pcboss's Avatar
Received 175 Upvotes on 153 Posts
If you install a single pole breaker you will only be able to supply 120 volt loads from the panel. A double pole breaker will allow you to run either 120 or 240 volt loads from the panel.
If you installed a single pole breaker only every other buss finger would be hot in your panel.
Old 03-16-09, 09:17 AM
I
Received 45 Upvotes on 43 Posts
Originally Posted by eeslick View Post
oso my question is to use a 100 amp breaker comming out of my 200 panel should it be single or double pole and why ???
thanks
Double pole, because that supplies 240V. Also because no one manufactures a single pole 100A breaker.
