What is the cost of NMWU-90 6/3 Wire??
Old 03-19-09, 01:23 PM
Hey just wondering if anyone could give me approx cost of NMWU-90 6/3 Wire per meter or foot?? We will be using it for our outdoor hot tub. THANKS!!
Old 03-19-09, 02:42 PM
Received 42 Votes on 40 Posts
Call your local electrical supply house, hardware or home center. The price varies from place to place based on the market. Get both the per-foot price and the per-reel or spool price if your length is near a standard length (100', 250', 500', 1000'). Spools and reels are cheaper than the per-foot price.
Old 03-19-09, 02:45 PM
That is something you have to find out locally. You need it to have insulated ground, or run that to your disconnect, and from that to the tub conduit, with the four insulated wires. You cannot have a bare ground wire to the hot-tub.
Old 03-19-09, 05:35 PM
As I mention before on othe other section the NMWU is not allowed to use for spa usage the code is very specfic on this matter in Canada the Teck cable or indivual conductors in the conduit are allowed.
Please check with your local inspector officals for latest info related to spa tub useage.
Merci,Marc
Old 03-21-09, 05:15 PM
I thought they took out the insulated ground requirement a few code cycles ago.
I sure cant find it on the 2006 CEC CD
Old 03-22-09, 01:53 AM
Thanks Electricguy for updating info here.,
Classicsat.,
If you can able find the info related to this matter please let us know and the Teck cable as well if still allowed too.,
Merci,Marc
