Back-to-back GFI's ?
Old 03-20-09, 12:10 PM
Received 4 Votes on 4 Posts
I am buying a 120 volt portable hot tub. It comes with a large plug which has a built-in GFI.
The spa dealer looked at my existing receptacle and wanted it replaced with a better one which would accomodate the large spa plug. Probably would have a bubble cover.
Spa dealer also thought the new receptacle should be a GFI.
My question is: Are two back-to-back GFI's a good thing. Or possibly, could they cancel each other out or ???
Old 03-20-09, 12:17 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
They won't cancel out if wired correctly..but I don't think you need it at all if there is one built on to the cord itself.
If this is an exterior outlet and a newer home (15 yrs or so, not sure when GFCI became required)..it may already be GFCI protected somewhere down the line.
Old 03-20-09, 12:57 PM
I would add the new GFCI so that, in three years or so, when you get tired of the spa, you can safely plug in a weed eater or other device at that receptacle.
Old 03-20-09, 01:45 PM
Received 42 Votes on 40 Posts
Yes, the bubble cover is required.
Yes it should be GFCI as you could unplug the spa and plug something else in there -- for example a shop vac used to clean the spa.
It won't hurt anything to have both GFCI devices.
The circuit for your spa probably needs to be dedicated 20A also, so you might need to pull a new circuit. What else, if anything, is on the existing circuit? Does the spa installation manual specify amperage?
Old 03-22-09, 08:26 AM
Ben: Spa requires only a 15 amp circuit. I have 20 amp.
Thanks to all who replied. I am good to go !Beer 4U2
