3 wire AFCI?
3 wire AFCI?
3-Wire Circuit
''An AFCI should not be connected to a three-wire circuit that contains a shared neutral
unless the AFCI is approved for the application''.
Does it mean no switched outlets in the bedroom without a special AFCI
Thank you
Thank you
Switched outlets are just fine on either AFCI- or GFCI-protected circuits. The three-wire circuits which you are referring to are those which are powered by a double pole breaker.
ibpooks Switched outlets are just fine on either AFCI- or GFCI-protected circuits. The three-wire circuits which you are referring to are those which are powered by a double pole breaker.
Thank you for the explanation
an AFCI is not a GFCI.
Had a brain-cramp ment to type AFCI
