4 gang box-best way to secure cables along stud?
Old 03-26-09, 03:38 PM
H
OK, wiring a 4 gang box and I guess I never realized how many cables that involves, espcially when two of the switches are 4ways! So what is best way to secure all the cables? They all are coming from above the box. Is the 4 wire cable stacker really the best way? Even with them I will have to run a stack up both studs in the bay. I am not crazy about them since they really let cables loose to move through them and do not secure the cable to the center of the stud like a staple. I guess I could have run some of the cables past where I wanted to go, come down a different stud bay to below box, and then go through stud to come from below--but that would have required forethought--I don't have enough cable unless I re-run some. Not a big deal as they are short runs and if that is really best way I can do that, but don't want to do if there is easier way.
Old 03-26-09, 05:19 PM
D
ya by code in British columbia canada the 4 wire stacker is what is called for it.. If your going to use staples you could but they have to be within 12" of the box and if you cant make that work use the stacker.. its not like the wires will be moving around once the wall is enclosed
Old 03-26-09, 09:51 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
the stacker is about the easiest way to accomplish what you want. If the wall is totally open, the other thing you can do is put a cross stud across the bay but turn it so it is flat against the back where it leaves the front half of the stud cavity open.
Old 03-27-09, 12:41 PM
T
How many cables are you talking about?
Old 03-27-09, 01:23 PM
H
lets see
1. incoming power circuit 1 14/2
2. a 4 way switch 14/3
3. second wire to switch above 14/3
4. wire to light outside door 14/2
5. wire to spotlights behind garage 14/2
6 a second incoming power for different circuit 14/2
7. a 3 way switch (start of the second circuit) 14/
so looks like (4) 14/2 and (3) 14/3
and since mudroom floor is platform built on top of concrete, there is no running of cables from below. they all have to come from up top.
like idea of 2/4 flat against sheathing. may use that.
thanks
Old 03-27-09, 05:57 PM
nap's Avatar
nap
nap is offline
New Member
sounds like you need to do a box fill calculation
Old 03-27-09, 10:00 PM
H
I had checked before and wasn't even close. Actually can eliminate the 2nd circuit power 14/2 since I can bring the power in at switch in other room. But with what I had written before
4 14/2----16
3 14/3----18
ground----- 2
4 switches-16
52
4 gang box--69 cu. in.
calculations look OK?
Old 03-28-09, 10:54 AM
pcboss's Avatar
Received 111 Votes on 97 Posts
Your calculation looks fine.
Old 03-28-09, 08:32 PM
nap's Avatar
nap
nap is offline
New Member
4 14/2----16
3 14/3----18
ground----- 2
4 switches-16
52
yes, if the box is 69 cube. I'll take your word for that.
