Intermatic Timer T-104 help please!
Old 03-28-09, 09:09 AM
Hello guys could someone help me out before I have to run out and get an electrician! I am pretty handy but i am having trouble with this timer.. My ten year old timer suddenly stopped turning so i purchased a new one thinking it was time but after replacing i found that this motor was not spinning either unless the switch is turned to ON.. Once you turn the switch to OFF the motor stops spinning..
This timer is 220 and it controls two 220 volt cable lines, each having a red a black and a white but the whites are not used and are tied together.. The blacks are connected to terminals 1 and two and the reds are connected to terminals 3 and 4. The motor is connected to terminals 1 and 3 everything exactly as the old one was. If anyone can help please let me know and thanks alot everyone..
Old 03-28-09, 09:23 AM
Sounds like you have one or both of the "incoming lines" connected to the "outgoing lines".
Read the instructions and use a multimeter. The connections for this are not necessarily like the old unit's. They like to switch things around!
Old 03-28-09, 09:35 AM
chandler's Avatar
Received 3 Votes on 3 Posts
I agree with Bill, make sure you have "line" going to T1 and T3. I believe you will find you have "load" to those terminals.
Old 03-28-09, 09:53 AM
Intermatic T104
Thanks guys so i should be connecting the two reds to terminal 1 and 2 and the two blacks to 3 and 4? Just remember that the old one was the reverse. Would it be the same if i just connect the motor to 2 and 3 instead of 1 and 3 how it is now?
Old 03-28-09, 02:24 PM
chandler's Avatar
Wait, don't go connecting wires according to color. Determine which cable is "line". Then attach those wires (black and red) to terminals 1 and 3, along with your motor leads.
Old 03-28-09, 03:12 PM
Intermatic T104
Yes thanks so just to make sure Line is the Hot wire correct?
Old 03-28-09, 04:07 PM
chandler's Avatar
Line is hot....load is....well, load.
Old 03-28-09, 04:19 PM
Intermatic T104
Thanks all.. i will work on it..
