breaker size for Kenmore washer/dryer
Old 03-29-09, 09:55 PM
I received a nice stackable kenmore 24 in. laundry center (stacked washer/dryer) from a friend - electric. Any ideas what size breaker i should be using? 2-pole 30? 2-pole 50? HELP!
Old 03-29-09, 10:25 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
What does the name plate say the amperage and voltage of each one is? Does one plug into the other or do they have separate cords and plugs? What kid of plug(s)? What is the model number?
Old 03-30-09, 12:53 AM
The nameplate useally be in the front of the stackable unit just open up the door and you will see the manufacter detail tag labled on the door somewhere.
Get all the voltage and amprage and let us know what it set up then we will go there.
There is one cricital item if you have electric dryer and need new circuit it must be 4 wire format if you have exsting set up let us know if that is 3 or 4 wire set up.
Merci,Marc
