Wiring 3 Phase 4 Wire 240Volt Breaker?
Old 04-13-09, 09:02 AM
X
So I am putting a computer in my office (a big one) that has a 4 wire hubbell connector. The manual says I should have 240Volts between L1 and L2, L2 and L3, and L3 and L1. The 4th wire is a ground.
This is 60amp 240volt, so should my breaker be a 3 pole breaker?
It will be in a commercial building so I am out looking for one to rent I am trying to find one that is already wired correctly.
I don't think I can use regular home 120volt service which would be a two pole breaker (240/208) with ground and neutral.
Anyone here wired something similar?
Old 04-13-09, 09:16 AM
A
You want a building with 3 service and office space with a 3 4-wire load center.
You need to check with the manufacturer to see if you can use it on a grounded B phase system (I think that's what it's called). That is 3 3-wire, and one phase is grounded. It's cheaper to install, but your computer may not like the fact that one phase and ground are at the same reference.
Old 04-13-09, 09:28 AM
X
3 phase 4 wire
The ac/dc/converter says 3 phase 4 wire.
SO Pump in 3 phases of 240/208? and one ground back to neutral bus bar in main panel.
If I have one leg at 120volts that no good, my brief understanding of 3 phase on a corner grounded delta says one leg is 120V, no good.
kevin
Old 04-13-09, 10:01 AM
I
Received 42 Votes on 40 Posts
You're confusing phase-to-phase voltage and phase-to-neutral voltage. Your three-phase appliance only cares about the phase-to-phase voltage so a grounded delta type system would be okay for this machine. A three-pole breaker of the appropriate amperage would be required.
Check with the manufacturer to see if this will also run on a 208V system that is much more common in commercial office space. Most equipment that runs on 240V can be field converted or will automatically work on 208V too.
Old 04-13-09, 10:15 AM
X
Thanks for all the replies.
I guess my issue is this:
Most of the commercial warehouses I have looked at have only 100amp 240 volt main panels.
This would be 120V(black), 120V(red), white, neutral.(like a house)
I believe what I need is 240v(black), 240v(black), 240v(orange), and ground to bus bar.
Is that 3 phase delta corner ground, or 3 phase wye?
It seems delta has a "high-leg", that would blow my system.
As above I cannot "convert" the system to run on anything but what it can.
I can run 60amp 240V, or 30 amp 480 volt, or about anything in between.
The manual says:
To verify the proper wiring for a 4-wire PDCA(Power distribution control assembly or basically the computers ac/dc power converter), use a DVM to measure the voltage at the in-line connector. Voltage should read 200 - 240 Vac phase-to-phase as measured between the connector pins as follows: L1 to L2, L2 to L3, L1 to L3.
Now I have looked at a few warehouses and I see 3 pole breaker and 2 pole breakers.
I found one with 480volt main with transformer, but did not look at y or delta specs.
kevin
Old 04-13-09, 10:42 AM
B
Received 35 Votes on 32 Posts
Is this similar to what you have?
Unpacking the PDCA
Bud
Old 04-13-09, 11:34 AM
X
yes but i have the ibm version
Unpacking the PDCA
Bud
I have the ibm version, power is the same.
I will email you a pic
kevin
Old 04-13-09, 11:42 AM
X
pictures of ac/dc/converter and cables
Old 04-13-09, 12:18 PM
I
The PDCA cannot operate on this single-phase system.
Yes, you do need a three-phase system, but the PDCA seems to be very flexible in the type of three-phase power it can use. There are a variety of color schemes which could be used (black, red, blue, orange, brown, yellow). It could run on a 208V, 240V or 480V system wired in a delta or a wye which should give you a lot of flexibility in finding a suitable site.
Either would work as long as the voltage is within the specified range.
A high-leg system would be okay.
The breaker poles isn't always a dead giveaway, because the building may have a three-phase main panel which is then split out into several single-phase panels throughout the building for lights and receptacles. So even if you only see double-pole breakers, there could still be three-phase in the building..
Old 04-13-09, 12:46 PM
X
Wow, thanks for the advise, as you are topic mod with 4200 posts I would have to take your word as gold.
Most small warehouses (under 1000 sq') seem to have 400-800volt drop at 240 amps, then it splits power to the individual units, 60-100amp mains (black, red, white, gnd-wrong power per previous post). However I have found a couple with a 480 volt main panel in the office, which feeds to a transformer which steps down to 240volt.
However on that one could I just put in a 30mp breaker on the 480 volt panel and feed off that?
As far as the sub panel goes I saw a huge 200amp panel and some had 3 pole breakers, I figure I would pull three "phases" from that and ground to the neutral bar right, considering if the breaker was the correct type.
I don't see how I could use a two pole 60 amp breaker and one 60 amp breaker unless I could sort out the three phases.
Thanks again, my problem is I can't drag a commercial electrician to every potential site to have him check the panel ya know.
k. brown
PS> bluevistarendering.com
Old 04-13-09, 01:12 PM
I
Unfortunately, the best I can say is maybe. There could be a 480V single-phase panel or it could be three-phase. That would require inspection by an electrician.
If you have three-pole breakers, then you have three-phase power.
You can't. A three-phase load cannot be used on a single-phase service.
Certainly not during your first look. It would be a good idea to have one meet you there for an hour's consulting before you sign the lease though. Three-phase commercial systems are substantially more complex than residential wiring, so there are 100 what-ifs that someone on-site really needs to see before you can say with 100% certainty the site is adequate.
Old 04-13-09, 03:46 PM
A
Yes, but you said earlier that corner grounded delta would be OK, and if that's the same as grounded B-phase, that system uses 2-pole breakers and is three-phase.
I am not an electrician and I don't mean to make this more confusing, but I sure was confused when I first encountered grounded B-phase and traced it back to a 3-phase primary.
http://forum.doityourself.com/electr...onductors.html
Old 04-14-09, 08:17 AM
I
That's true, but I also said a few posts back that there are some circumstances where a panel with two pole breakers might be able to supply three-phase.
I agree. These types of systems can be very confusing and complex which is why there really aren't any "rules of thumb" with three-phase like there are with residential single-phase services. Every situation is different with some nuance of how the transformer(s) are hooked up or panels are laid out.
