220 to 110 wiring question
Old 04-23-09, 11:09 AM
The wire running from my load center to my 1.5 hp 220v water well pump is 10/2 w/ ground, i.e., it doesn't have a neutral wire.
I want to take 110v off of either the contacts on the pump side of the pressure switch or in the control box, so that I can have a 110v circuit with a single outlet box that is only hot when the pump is running. The circuit will be used to power a 110v AC to 12v DS wall wart, which will be input to a relay.
So...my question is how do I get a neutral conductor to to the outlet box, or do I need one? If not, exactly how is the outlet wired?
In case it makes any difference, the circuit breaker for the well pump is in a subpanel that has a floating/non-bonded neutral.
Thanks,
Ira
Old 04-23-09, 11:57 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Use a relay with a 240v coil instead of a low voltage coil and wall-wart. Run the relay coil off the pump contactor. If you tell us what the relay will control someone may have an even better idea.
Old 04-23-09, 12:49 PM
I already have the relay, so I would rather use it.
I know the way I'm doing it sounds kinda wierd, but using a plug-in wall-wart also allows me to easily remove voltage to the relay (it's a wall mounted, self-contained/enclosed relay) without having to shut down the well pump or remove the wires running from the pump switch or control box.
Ira
Old 04-23-09, 12:55 PM
ray2047's Avatar
You would need to change the two conductor wire to your pump to three conductor wire. That to me seems a lot more work and cost then just using a relay with the right size coil. You can always turn off the relay with a switch.
Old 04-23-09, 01:02 PM
Yes you need one. The only way to get one it to run one.
Overcurrent protection is also an issue. You need the right level of overcurrent protection. You didn't say what size the breaker was so we have no way to tell with the information we have now.
Old 04-23-09, 01:11 PM
It has a 20 amp breaker.
It's actually pretty easy to run wire thru the conduit to the pump house. Can I just run a single 12ga. wire from the neutral bus to the wall outlet?
Old 04-23-09, 01:12 PM
Received 42 Votes on 40 Posts
It has a 20 amp breaker...Can I just run a single 12ga. wire from the neutral bus to the wall outlet?
It has to follow the same path as the hot, but yes that is what is needed.
Old 04-23-09, 02:02 PM
That's good. It eliminates that issue.
Old 04-23-09, 02:23 PM
One option is to find a power supply that can run off of 240V, and plug into a 6-20 receptical, or get a 240V to 120V transformer.
