adding a outlet
Old 05-01-09, 06:49 AM
adding a outlet
I have a outlet on the inside wall of the house and I want to add a outlet behind this one that will be on the outside of the house ib the car port.How do I put the box from behind the other outlet so I can run the electric from one to the other
Old 05-01-09, 07:13 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
If it is not kitchen, bathroom or dining room space it 2" above the top of the existing receptacle or 2" further to the side in the direction away from the stud or 2" below. It can be higher but when going to the side be sure you are in the same stud bay. Use a short piece of NM-B (Romex)* between them. The receptacle must be GFCI.
* #12=20 amp breaker #14- 15 amp breaker
Old 05-01-09, 08:04 AM
It is in the livingroom right next to the sliding glass door
Old 05-01-09, 08:45 AM
ray2047's Avatar
In the living it is ok to use it.
Old 05-01-09, 08:56 AM
P
There may be a "KO" in the rear / back wall of the outlet-box. If so ,and if you can remove the "KO", then you can "link" the new / existing boxes together with nipple.
Old 05-01-09, 05:50 PM
ok.Another question,on the outside it is siding.What is the best way to find the back of the other outlet.Without drilling a bunch of holes in the siding
Old 05-01-09, 06:13 PM
ray2047's Avatar
With respect this might not be a good idea. Sometimes the wall is not deep enough to have two boxes back to back. (Yes, been there done that.)
Drill from the inside with a long 1/8" drill bit. You can get them 12" long but with siding a 6" long one may be enough.
Old 05-01-09, 06:19 PM
D
Received 1 Vote on 1 Post
OP doesnt state location.. but up here at least, a carport receptacle must be on its own circuit from the panel (but you can also put carport lighting on the same circuit). It also has to be GFI protected (considered to be 'outside').
If the climate is cold, and you're going to be using a block heater on the circuit, you might find you're tripping breakers alot (what else is on this living room outlet circuit ?)
Old 05-02-09, 09:57 AM
pcboss's Avatar
Received 148 Votes on 131 Posts
In order to find the inside box just measure from a fixed point like the door frame and the floor.
Old 05-02-09, 01:09 PM
I am in florida.Dont have to worry about the cold.The only other things on that circuit is a couple of light sockets and the tv
Old 05-09-09, 10:20 AM
jatco's Avatar
I was under the impression that an exterior outlet had to be on a dedicated (20amp) circuit (GFCI'd of course)?!?.
That's what I discovered on this site when I wanted to the same.. and did it that way.
Old 05-09-09, 10:43 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Jatco..maybe different in CA? My house has exterior outlets tied to the garage and kitchen circuits (GFCI) look original, house built in '90. House in VA had 1 ext outlet in back, same circuit at garage as well.
Old 05-09-09, 10:58 AM
jatco's Avatar
That wouldnt suprise me.. but DaveC72 does mention that too, above..!
