Electrical overhaul
Old 05-11-09, 10:41 PM
Electrical overhaul
Hello all. I just purchased an old farmhouse that needs some work. The major project is updating/repairing the wiring in the home. I'm confident that I can accomplish this myself, with one caveat... I need to work one room at a time. I'm just wondering how I can wire everything down to the panel a room at a time without having to call an electrician out to re-establish connections at the panel every time. Would an electrician accept an upfront payment for repeated visits to wire the panel on room at a time? Thanks - J
Old 05-12-09, 01:01 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
First tell us about your main panel. Breakers or fuse? Size of main breaker or fuse? If a breaker box is it full? What is the make and model if a breaker box. Ate there any subpanels? If so their size and actual loads on them such as pumps or machinery. Do you have electric heat, electric stove, electric water heater, electric clothes dryer?
Old 05-12-09, 08:21 AM
I
Received 45 Votes on 43 Posts
The real trouble with the piecemeal approach isn't so much the electrician as it is the permit and inspection process. You want to break the work up into big enough chunks so you don't have to pay a bunch of permit and inspection fees, which will also of course save your electrician a lot of wasted labor.
Old 05-14-09, 11:03 AM
Z
Received 319 Votes on 285 Posts
If you're comfortable with wiring and appropriate codes for the rooms that you'll be working in, you may be able to become comfortable connecting and disconnecting branch circuits in the main panel. By turning off the main breaker, you remove power from the buss bars and breakers (though the large incoming wires are always hot). Working carefully and methodically, you can run the wires into the panel and to their respective breakers.
More of the issue that I run into when doing one room at a time is abandoning the old circuits. Invariably, the one circuit I disconnect for the room I'm working in controls 5 other receptacles that are used daily, which makes it a logistics exercise, with the use of some temporary extension cords to keep the microwave, TV, table lamp, and other key household items working.
