Running Romex on steel beam
Old 05-17-09, 10:38 AM
R
I searched the forum but did not find the answer
Can I run romex along the web of an I steel beam to span the width of my unfinish basement so I dont have to make more holes in the joists
I can secure vertical blocks between the top and bottom flanges and staple the Romex to the blocks.
The top flange has a bunch of 1/2 holes,wondering if I can use them to run the wires from the joists to the web.
Is this set up OK if one day I finish the basement and box the beam?
Thank you
Old 05-17-09, 11:17 AM
chandler's Avatar
Received 6 Votes on 6 Posts
As long as you will be closing it up and the romex will be protected, there should be no problem any larger than running romex across any beam or joisting system.
Old 05-17-09, 05:48 PM
A
As always, check local requirements.
Here are some beam clips intended for use with MC or AC. You may be able to find something similar for Romex.
CADDY Cable Snap Clip
Old 05-18-09, 03:13 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
I have used the wood blocks inside the web like you described. I cut them tight and put some construction adhesive to hold them to the web. Staple the cables to the blocks.
Old 05-18-09, 08:34 PM
Perfectly legal as long as its not subject to damage. Use common sense and you will be ok.
Old 05-18-09, 08:36 PM
F
That will be no issue if done right as few poster menton few good ways to do this.
Merci,Marc
Old 05-18-09, 08:39 PM
R
Thank you for replies
Im not shure why I need to close it up
[box it?]to protect the wire staple to the side [web] of the steel beam but there is no need to close the joist space when wires are staple to the joists side
Old 05-19-09, 07:25 PM
Its all about affording protection to the wire, that's all. For example, you cannot run your Romex on the bottom of the joists, either parallel or perpindicular to the joists (without some kind of running board or some other protection).
Same goes for the attic, only this time you would be on top of the joists, or in some cases, the rafters.
Old 05-20-09, 04:30 AM
chandler's Avatar
Rodel, you mentioned "box the beam" in your OP, so I was under the impression you would finish the area. Maybe I misinterpreted what you were doing. Running the cable through the web of a series of beam trusses doesn't need support if you are finishing it off and protecting the cable. If you won't be closing it up, then you will need the mentioned support methods.
Larry
