Outside lights with gfi
Old 05-28-09, 12:40 PM
Ok guys what i want to do is i want to run 2 halogen lights along a concrete wall in conduit. and from the last light at the end of the line i want to come down with a piece of conduit and put a gfi i am going to tap power from the garage my question is how can i make the gfi at the end of the line live all the time because the 2 halogen lights are going to be switched? I know i would be able to do it if i run 12-3 uf-b but really dont want too because it wont fit inside 1/2 emt and i already have everything i need in 1/2 inch do i have any options I am also going to put a gfi on side of garage before it goes outside but that i know i will be able to make live all the time any ideas?
Old 05-28-09, 12:53 PM
Received 42 Votes on 40 Posts
You just pull another different colored hot through the conduit in addition to your black, white and green; make one switched and one always on. Red is usually used for switched, black for always on.
If the lights and receptacle are on the same circuit, they may share the neutral and ground.
Old 05-28-09, 12:55 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
UFb really isn't intended for use in conduit so no real problem. Use the correct wire. Single conductor THWN. If you need to run wire to the wall you can run conduit all the way or transition from direct burial UF at the beginning of the conduit using a junction box.
Old 05-28-09, 08:20 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Be sure to use compression fittings for the EMT. Set screw are not rated for outside. Also, if your run is entirely in conduit, from where it starts (panel or grounded metal j-box) all the way to the last metal box (weatherproof), you may use that for your ground.
