solution for small breaker
Old 05-31-09, 01:25 AM
Z
I have a situation where I have 20 3 phase machines that draw a total of 120 amps. These machines are fed via 1/0 cable connected to a 100 amp breaker. The panel is a Square D QO series and unfortunately they dont make anything larger than tht 100 amp breaker.
Can anyone tell me if there is a way to split the load to 2 breakers without doing major wiring changes?
Old 05-31-09, 02:52 AM
F
If you have 3 phase QO series load centre and if you have 200 amp or larger main breaker or main lugs load centre yeah there is a beast on market but it not going be cheap btw.
this is a subpanel or what ??
need more info here
Also if this is a commercal building you will have to get a hold of electrician to deal with this due the safety issue there.
They will able check it out to see what is the correct way to fix this situation is.
Merci,Marc
Old 05-31-09, 06:54 AM
Z
This is the Square D push in type, main panel 225 amp main lugs. There is a separate 200 amp disconnect breaker/enclosure.
need more info here
Merci,Marc
