run a 220 volts for electric dryer
Received 0 Votes
Hi everyone,
I just got a new electric dryer, but the technician said its need 220 volts, i thought it had 220 volts on the plug, 3 pronzes with an L shape, the adapter fits perfectly with the dryer plug. i thought there was something wrong with the dryer. but after the technician came out and check, its only produce 110 volts, the dryer does light up and tumble, but doesnt produce any heat. so i guess the electricity doesnt produce enough juice to heat up the dryer.
how do i run a 220 volts plugs to feed the dryer from the electric panel? what do i need to make the dryer work?
as u can see, im pretty rookie with electrical stuffs. any help would be appreciated. Thanks
Are you in the USA?
You probably need to run a new 4 wire cable for the dryer but what you are saying doesn't make sense so if it is a home made adapter that may be your problem. That's why the questions. You may just need a different cord on the dryer.
Received 0 Votes
Hi,
yea, im in the usa.
the plug looks similar to the male plug, fema 10-30p. its a pretty good size panel box with 100 amp. i just bought this house and i believed the former owner diy the plug from the electric panel. clothes was hanging all over the basement eventhough he got himself a dryer. so i guess he might have wired its wrong?
yea, im in the usa.
Not the size of the panel. The amp size of the dryer breaker. Is the cord on the dryer three prong or four prong? Do you have an analog multimeter? We will probably need to open up the dryer receptacle and see what is there but first answer my questions.
Just a couple of notes: You never use an adapter on a dryer. If the dryer is four prong and receptacle three wire then the cord needs to be changed to three prong and the neutral in the dryer bonded to the case according to manufacturer's instruction..
