Whole House Fan Switch
Old 06-10-09, 01:32 PM
I just purchased a 2 speed Master Flow 24" Whole House Fan (WHFS24M). Is it possible to wire the fan so that I can eliminate the pull chain and use a wall switch or a variable speed wall switch?
Old 06-10-09, 03:31 PM
Yea... first is it a direct wire fan or one that plugs into a wall outlet? All you need to do is add a switch from a circuit nearby or run a dedicated one from the panel depending on what the load of the fan is, and than just wire direct into the fan or into a new receptacle if the fan has a cord. Than just keep the chain pulled to the on setting and than just control it from the switch you just added. There is no reason to rewire the fan. Also you may void the warranty by trying to get inside it and bypass the chain switch unless the documentation says that it can be done. If your trying to control the speed from the wall switch just keep the chain pulled to the fast setting and install a wall dimmer(fan speed control) rated for use on a fan... make sure the watt and voltage rating exceed what the fan pulls. A rule of thumb is to make sure the dimmer is not loaded more than 80% of what it is capable of handling. To figure this, take the watt rating of the fan and multiply it by 1.25, the answer will be the minimum watt rating the dimmer can be.
Best of luck,
Paul
Old 06-10-09, 05:52 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Since your fan has a split capacitor motor the same as newer ceiling fans a ceiling fan speed control should work.
Master Flow® Direct Drive Standard Whole House Fans
WHFS24M
* Efficient, Long-Lasting Motor...
1/4 hp permanent split capacitor design
* Easier To Wire...
2-speed pull chain switch controls operation (no wiring through walls required)
Old 06-10-09, 08:07 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Double posted in the lighting section. Look for answers there, too.
