Mixed wire gauges
Old 06-13-09, 04:06 PM
Mixed wire gauges
I'm nearing completion of my basement wiring. I've only got wiring to run for the last light of 15A lighting run and the last receptacle on a 15A GFCI receptacle circuit. I've run out of 14/2 cable but I have enough 12/2 to finish the job.
I understand that 12 gauge is fine with a 15A circuit, but will my inspector likely have a problem with the mixed gauges?
Old 06-13-09, 06:26 PM
If you let the inspector know about mixed wires and as long you have legit 15 amp breaker then you will have no issue with it.
I done that all the time with larger conductors as well { you should see me what I do with parking lot luminaries }
Merci,Marc
Old 06-14-09, 12:37 AM
I was in that exact same situation when I built my man cave. I had spent a couple of thousand and figured that another $50 to do the job properly was within the budget.
Just out of curiosity, why did you run a 14/2 15a recep circuit? 12/2 20a would serve you better.
Old 06-14-09, 01:28 PM
Tolyn Ironhand's Avatar
Received 74 Votes on 66 Posts
Because 14 ga wire is easier to work with. The benefits of running #12 is only a negligible increase in capacity. At least that would be my reasons.
Old 06-14-09, 01:51 PM
All my new receptacle circuits are 20A. This last one is relocating a receptacle that is on an existing circuit in the unfinished side. It's already there, but is now in an inconvenient place.
