Recessed light clicks on and off
Old 06-14-09, 06:49 PM
Hi-
Few years ago, I installed four recessed lighting on it's own 20 amp circuit with a dimmer.
Few days ago, one of the light wasn't lit, so I thought it blew out and was about to change, then I heard a "click" and the light came on. It would do this couple of times day so now I am wondering if this is a fire hazard?
Any ideas on troubleshooting it?
The canister is a sealed unit (square one) with IC approved.
Thanks in advance for your help!
Old 06-14-09, 07:11 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Failing thermal protector or over wattage bulb. If you can post manufacturer and M# the pros can tell you if the thermal protector can be replaced.
Old 06-14-09, 07:52 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
I suspect over lamped for the trim installed. On the inside of the there should be a list of trims with the max size lamp approved for that trim.
Old 06-14-09, 08:13 PM
Hey Guys-
It's Halo 4" 50-Watt Incandescent Recessed Light Housing, sold at Lowes
(hxxp://www.lowes.com/lowes/lkn?action=productDetail&productId=60607-337-H99ICT&lpage=none)
I have Sylvania PAR 20 (50w, 120v) bulbs installed in all four canisters.
Could it be that this particular canister is defective? I've never had issues with them before...
Old 06-15-09, 04:53 PM
Yes, it could be that, as Ray pointed out, the thermal overload is failing.
Another thought, is there insulation next to the can and if so are they IC rated?
Old 06-15-09, 05:33 PM
ray2047's Avatar
Old 06-16-09, 07:57 PM
Fine! Be that way. :P ................
Old 06-17-09, 07:16 PM
Thanks so much for comments from all of you.
Although the canister is rated 50w, I thought the bulb was too hot so I am going to notch it down to 25w or so to see if it makes a difference. I will post back with results...
