metal cables with plastic boxes
Old 06-17-09, 09:21 AM
Can we discuss of what should be done in this situation if rewiring is not to occur?
My daughter's place has 2 wire BX, no ground, no continuous wire.
The box was metal, the outlet 3 prong, so it is likely that the ground prong was indirectly conducting to the sheath.
The box was replaced with plastic (the metal box was loose) , so I guess this is slightly better since the ground prong will not be a fire hazard (although it may be worse in the case that it could be a more likely electrical shock hazard)
But, I am guessing the better thing to do would be to put a GFCI outlet in the box, marking the outlet as "no equipment ground" with the included sticker. I am thinking this would better protect against fire and shock.
Would this be an acceptable thing to do?
Thanks,
Larry
Old 06-17-09, 09:37 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Post deleted.
Old 06-17-09, 11:08 AM
pcboss's Avatar
Received 30 Votes on 26 Posts
Metallic cables need to be used with metallic boxes. The plastic box should be removed and repalced with a metal one.
The ground pin only carries current on the event of a fault or short circuit. There should not be any current at any other time.
Old 06-17-09, 02:21 PM
Received 42 Votes on 40 Posts
I certainly understand the logic in the switch to plastic box, however the code is pretty specific that metal boxes must be used with metal sheathed cables (BX/AC, MC). Even a poor ground is better than no ground, although the poor ground presents some problems too. I'm sure you've heard of the stories of red hot BX cable.
Yes that's right. In fact you might even want to consider using a GFCI breaker instead as that will also protect all of the cabling inside the walls whereas a receptacle can only protect the downstream cable. The breaker is a bit more expensive ($30), but it does provide a small measure of added protection if you're not as concerned with the price.
