Box extenders Q
Old 06-20-09, 11:56 AM
Box extenders Q
Does a box extender increases the box fill?
Extenders for 4'' octogonal boxes have 15 Cu in volume so I m wondering if I can add this volume to the box for fill purposes
Thank you
Old 06-20-09, 12:16 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Yes, sort of like a plaster ring, but only the volume equated by the measurements of the extender.
Old 06-20-09, 03:14 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
You are speaking of the extension that simply looks like the box you are mounting it on with the back removed, yes?
If so, the displacement should be listed on the ext.
If not, the ext can be calculated but rather than do that, here is the code listings of box displacement for a 4" round/octagonal
4X1 1/4 12.5 c.i.
4X1 1/2 15.5 c.i.
4X2 1/8 21.5 c.i.
the dimensions for the rings are the same
The ring is most likely a 1 1/2" ring.
Old 06-20-09, 05:26 PM
It is the one with the back removed 15.5 cu
Thanks again
