Toggle switches
Old 06-20-09, 03:55 PM
Toggle switches
I'm looking for a toggle switch that completes two circuits at the same time. The connections must remain separate. The only option I can come up with is two separate switches linked together, as I can't find a single switch that does this.
The switches should be the smaller kind (not something like a household light switch), on/off or 3-way toggles are fine.
Does anyone know where to pick this up, or have a clever way of wiring that would allow this with a single switch?
Thanks,
daon
Old 06-20-09, 04:34 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Double pole, single throw comes to mind. Try Radio Shack. More information about the use of the two circuits would help us.
Old 06-20-09, 04:37 PM
Received 41 Votes on 40 Posts
I believe you are looking for a DPST (double pole, single throw) switch. These are pretty typical in a typical light switch format (usually used for controlling 240v loads).
If you're looking for something smaller (and possibly for lower voltage), take a look at digikey and search for either DPST or probably more commonly DPDT (double pole, double throw) switches. They should have 20-30 different ones in different form factors.
