Hot Tub cable run
Old 07-13-09, 04:49 PM
Smile Hot Tub cable run
I am installing a hot tub in the backyard, approximately 5 feet away from the house and where the gfi sup panel is installed. Considering the short distance and the area where the cable is suppose to be running is not accessible (no traffic), is the use of liquidtight metallic conduit be appropriate for the application?
Thanks
Old 07-13-09, 08:31 PM
Tolyn Ironhand's Avatar
Received 68 Votes on 60 Posts
I see no reason that you could not use it as long it is not subject to physical damage. Just make sure you use the proper fittings and be aware of any grounding requirements.
