Touchplate System trouble
Received 0 Votes
is anyone familiar with the old touchplate systems? my house has it and the bathroom light wont go off. it flickers, but wont shut off. i can hear the relay click nice n loud, so i assume the relay is fine. i replaced the transverter, but that didn't fix the problem. anyone know what the problem might be? any help would be soooooo appreciaed!
Received 0 Votes
Welcome to the forums.
The relay clicking doesn't necessarily mean it's contacts are working properly. If the contacts are shot they'll stick and cause the symptom you described.
Pull the power to the relay coil to check it. Without power to the coil, the relay should disengage and completely shut off the light. If it doesn't, the problem is in the relay itself. If it does shut off the light, the problem is on the coil side.
Received 0 Votes
If you have low voltage switching set up in your house then more likely the relay is the cuprit.
You will have to find a electrical box where is alot of relays located and yes you can get new one the relay itself is GE RR-7 somecase it will be RR-5 Verison
Here what RR-7 look like
Those item useally found in electrical supply centre.
Merci,Marc
Merci,Marc
Received 0 Votes
rick, you spoke of the relay as if it were two separate components - you said to first check the relay then check the coil. are you talking about each side of the relay? or is there yet another component that you are calling the coil? i think youre just referring to both sides of the relay, but i want to make sure.
i just went up there and disconnected the whole relay and yes, the light went off. but i reconnected another old relay that was no longer in use and now the light will not come on. I will hopefully assume that that relay is bad too (thats why its no longer in use). i will be going to get a NEW relay weds, but i thought id try that first.
Received 33 Votes
A relay is simply an electromagnetically operated switch. It has a set of contacts like any switch and then an electromagnet (or two in this case) to cause the contacts to move to either a closed (on) position or an open (off) condition. The electromagnet is made up of an iron core and a coil surrounding the core. Energizing the coil causes the iron core to become magnetic and it is this magnetic field that causes the switch contacts to change state.
For all practical purposes it is not possible to separate the electromagnetic parts from the switch contacts for individual replacement so the entire relay assembly needs to be replaced.
Received 0 Votes
ok. thats what i figured. i have one more question; my old relay has only 2 wires (black n black) coming from the coil end. my new one (2500B) has four wires (2 yellow, a red and a brown). should i just double them up according to each side or should i not even connect the remaning 2 wires? which wires should i use?
Received 0 Votes
What manufacter brand name it is ?
The reason why I asked here due there are too many items that have word " 2500B " once I know which manufacter it is then we can able dail it down to correct connection sequince.
Merci,Marc
Merci,Marc
Received 0 Votes
it the official Touchplate brand out of Houston Texax.
Received 0 Votes
To use the new relay with old wire format.
The Brown and Red is your relay source the Yellow's are for LED indentication light
so you hook up the Black to red and other Black to Brown it should work with that set up.
I did look at the manufacter's website and they look simauir to GE RR-5 and RR-7's but make sure you have at least 24 volts to run the relay properly if not it may not function at all.
Merci,Marc
Merci,Marc
Received 0 Votes
well, i went up there early this morning and did everything as was instructed to me and.........IT WORKED!!!!
it works great and i want to thank everyone who helped me with suggestions, recommendations, wiring orders, etc.
thank you thank you!!!
Received 0 Votes
Vous êtes bienvenus.
You are welcome.
Merci,Marc
You are welcome.
Merci,Marc
Previous Thread
Next Thread
