Miniature Plug-in Relay, simple wiring diagram
Old 07-24-09, 03:32 AM
Type R – Miniature Plug-in Relay
and Wiring Diagram
please refer to page 6 of this link
http://stevenengineering.com/Tech_Su...Fs/45RGENR.pdf
first wiring diagram has
inputs 1 & 5
output 9
coil 13 , 14
When the coil is energized,
Is this diagram saying
In order to see voltage at the output
voltage must be applied to both inputs 1 & 5
or
voltage must be applied to one or the other of the inputs ?
thanks in advance
Old 07-24-09, 03:39 AM
B
Received 37 Votes on 34 Posts
Hi Mark, What the diagram is telling you is which contact is the normally closed and which is the normally open. 9 is the common contact and with no energy applied to the coil 9 and 1 are connected. Apply energy to coil and 9 transfers to 5 and 9 to one opens. This allows you to turn something on or off when the coil is energized. Does this help?
Bud
Old 07-24-09, 07:38 AM
W
Mark - as Bud mentioned, energizing the coil will change the internal connection of the relay from 9 & 1 to become 9 & 5.
The verbage "normally closed" and "normally open" refer to the state of the contacts with the relay in the "on-the-shelf" state. That means the relay coil is NOT energized, just as it would be sitting in it's box up on the shelf.
Terminal/contact 9 is called the COMMON terminal.
Terminal/contact 1 is called the "normally closed" contact, a.k.a. NC or N/C, because the path between 9 and 1 is closed, or connected, when the relay is in the normal on-the-shelf state (NOT energized).
Terminal/contact 5 is called the "normally open"contact, a.k.a. NO or N/O, because the path between 9 and 5 is open, or NOT connected, when the relay is in the normal on-the-shelf state (NOT energized).
Usually the switched power or signal wire is connected to the COMMON terminal (#9 in your case) and the wire(s) going to whatever you want to do by energizing or de-energizing the relay are connected to 1 and 5. You can use either NO or NC, or both depending on what you want to do.
In wiring schematics, if the schematic shows this:
--||--, this represents wires connected to NO contacts (in your case 9 & 5)
If it shows this:
--|/|--, this represents wires connected to NC contacts (in your case 9 & 1)
Old 07-24-09, 08:36 AM
Thanks Willis & Bud
It's all clear now. I'm ordering the relay now
You fellows have been great
