bathroom gfci
Old 07-27-09, 07:15 PM
bathroom gfci
hello all i'm very new to this site and am finding it quite helpful.
My question is can i put a gfi outlet first in the line and then
have two switchable lights following the gfi or do i wire the lights
first in the run and end it with the gfi outlet
thanks for the input.
Old 07-27-09, 07:59 PM
F
Received 36 Votes on 28 Posts
As long as the lights are not required to be GFCI protected (not inside the shower or tub area) either way will work. Generally it is desirable that the lights not be GFCI protected so that if the GFCI trips you are not left in the dark.
