220V relay question
Received 0 Votes
220V relay question
I'm trying to wire a thermostat relay (24V coil) to control a 220V A/C unit. The whole unit runs off of two 'hot' wires, one black, one white (supposed to be black). My question is: what kind of relay (SPDT, DPST, DPDT, etc) do I need? I think I will need a DPDT, dual pole dual throw relay. If so, which wires go where?
You would just need to get something like this Dayton 2UTL4 Definite Purpose Contactor with a 24 volt coil. You can get one like this or a 2 pole.
Your line leads would just terminate on the top 2 poles and load out of the bottom. Of course your 24 volts would terminate on the coil.
It would also need to be in some sort of enclosure.
Received 0 Votes
Thanks a lot, I definitely need a definite purpose contactor like you said; smaller DPDT relays won't handle the amperage I'm needing. Another question, though: when I was trying to wire it to a smaller relay, sometimes the breaker would throw, sort of. It wouldn't go all the way to the "on" position. I would change up my wiring, re-throw it, and it would be fine. What does it mean when a breaker is doing this?
Received 0 Votes
Yep, that was it. I had it wired with a single-pole switch, and one way I had it, it must have been connecting black (120V positive) to white (120V negative), throwing the breaker. Thanks a lot. Let me just be sure, 2 pole contactor, 220V: black and white line in the top, black and white load out the bottom, 24V lines wired to the coil, no thrown breaker, correct?
