4 Way Switch w/ power & light at first switch??
Received 0 Votes
Hello Everyone,
I have torn down some walls in my basement and trying to relocate some light switches. I have done search after search looking for my situation only to find everything except mine. I have 6 recessed lights hooked up to (2) 3-way switches and a 4-way switch in between. The problem I am running into is that the main feed as well as the first light come in at box #1 (3-way switch). I can't find a diagram that explains how to hooked it all up with this situation. The other lights run off of each other. Can someone help me out? Thanks!
You will have an odd color screw on each three way. The other two are travelers. The travelers of 3-way_A go to one side of the 4-way the travelers of 3-way_B go to the other side. You use three conductor cable for this. The white of the three conductor cable is recolored black. The two blacks are used as the travelers. At the four-way the reds are wire nutted together.
3-way_A is where the power and light come in. At 3-way_A both (neutral) whites wire nutted together. Black of light to common of switch. Black of power in to red.
At 3-way_B black and recolored black to travelers. Red to common.
The grounds are extended and connected to all switches and fixtures and any metal boxes.
The color chosen to recolor the white of the three conductor can be any color except green. But to avoid confusion it should not be red and it is not left white because it is not neutral.
Received 0 Votes
Thanks! I think I may have it but I am a little confused. Maybe it would be easier if it is explained by what wires are coming into what box.
Box A (3-Way) has = (Main Power wire) black, white, ground ; (Light wire) black, white, ground and (3 wire to Box B) black, red, white, ground
Box B (4-way) has = (3 wire from Box A) black, red, white, ground and (3 wire from Box C) black, red, white, ground
Box C (3-Way) has = (3 wire to Box B) black, red, white, ground
Can you some how explain with this what wire is connected to what in each box? Your help is appreciated!
Box B (4-way) has = (3 wire from Box A) black, red, white, ground and (3 wire from Box C) black, red, white, ground[
*On the 4-way swirch you have two screws of one color and two screws of another color. Each set of colored screws is a "side". In other words both travler wires from a switch to the same colored screw.
