no electricty in basement or living, need advice asap
Old 08-08-09, 08:02 PM
B
hello all
my girlfriend's mom has 2 power strips plugged into the same outlet, both full. she unplugged them during a storm and as she was plugging one back in the outlet "sparked and popped" and now there is no power in that outlet or any that share the same circuit on the breaker. The breaker is not thrown - but is a little loose (?) ive tried testing all of the outlets with a gfi tester (even though they arent gfi outlets) to no avail and dont have a multi meter on hand.
i am not an electrical person - i can do all the plumbing and building you want but im not very familiar with electrical.
to recap: "spark/pop" when plugging in power strip, no electricity in that room or basement, breaker not tripped, no gfi/gfci outlets that i can find
advice?
Old 08-08-09, 08:30 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You need to turn off the breaker and open the box. See whats going on. Move any wire inserted into holes in the back of the receptacle (back stabs) to the screws. Reinstall receptacle and turn on the breaker. May not be it but it is a place to start.
Old 08-08-09, 08:36 PM
H
Stupid question I'm sure, but you said the breaker was not tripped in the panel. Even though it may not have looked as though it was tripped, did you still turn it off, then back on just to verify? Most likely you have, but I've run into instances where the breaker looks fine, yet it really was tripped.
Otherwise, definitely make sure it's shut off and take a look at the outlet that's having issues. Also, are you sure it's not a GFI protected outlet that needs to be reset somewhere upstream?
Old 08-08-09, 09:47 PM
ray2047's Avatar
Good point since it is a basement.
Old 08-09-09, 08:12 AM
Tolyn Ironhand's Avatar
Received 343 Votes on 296 Posts
Try bypassing the power strip. I have gotten many a service call because they had no power and I find the problem is not the circuit, but the power strip. Some power strips even have their own overloads. Look for a button thing sticking out of the side of the strip.
Old 08-11-09, 10:08 AM
B
thanks for all the suggestions, not more than 10 mins after posting i found a multi meter in a closet and went and tested the breakers in the panel, and it turns out the one that was labeled correctly (basement and living room) was bad. took me less than 5 mins to replace it.
Old 08-11-09, 11:51 AM
I
Received 44 Votes on 42 Posts
I'd check out that receptacle too. If it sparked and/or popped, that means you probably have a loose or exposed wire in that box that should be fixed too. A loose receptacle will heat up over time and can burn if not replaced.
