re routing K & T
Old 08-11-09, 01:29 PM
G
re routing K & T
I'm doing a complete re wiring of my house...to replace the K & T.
While running power cable and installing boxes i'm running into K & T circuits blocking my routes.
Is it a wise move to re route these wires using new power cable?...i'd use junction boxes of course.
Thank you
Old 08-11-09, 01:57 PM
I
Received 44 Votes on 42 Posts
I guess I don't understand the problem. If you're replacing the K&T why not just rip out or abandon the old stuff that's in the way?
Old 08-11-09, 02:26 PM
G
Ahhh if life were so easy.
I'm living in the house..i'm rewiring and upgrading the service.
Once the new circuits are in i'll be getting a pro in to do a complete switch over.
Old 08-11-09, 02:40 PM
pcboss's Avatar
Received 141 Votes on 125 Posts
Is there any reason why you couldn't just parallel the old by moving over a few inches?
Old 08-11-09, 02:46 PM
ray2047's Avatar
Received 14 Votes on 12 Posts
Some pros won't want to touch wiring you put in because of potential liability and even if they will some of it may need to be done over to meet what they think is correct. If you aren't going to do the whole job you may be wasting time and materials.
Old 08-11-09, 02:56 PM
G
In several instances i've done that, being circuitous with my runs has also helped, but now I have a few areas that have me stumped...example: it's an old house with no light at the top of the stairs...code says put one there...4 K & T wires run up the stairs and along the hall right in the middle of the ceiling...blocking access for a good light-box install.
Old 08-11-09, 03:03 PM
G
I've done my homework....several electricians have said it's ok for the home owner to pull the wires and as long as the inspector ok's the work they'll do the hook up.
Also, previous to my rough inspection i'll be bringing in a pro to give my work the once over.
