buzzing noise in junction box
Old 08-12-09, 10:56 PM
K
Hi all,
I noticed there was some kind of buzzing noise in a junction box in the basement. I don't think that is a breaker box. Here is a photo of the inside of the box.
Any suggestions would be appreciated!
Thanks!
Kevin
Old 08-13-09, 03:45 AM
W
Received 1 Vote on 1 Post
This is a contactor inside the box and switching (turning on/off)
2 circuits.
The buzzing sound is the coil is energized and the contacts are pulled in.
It may be possibly for some outside lights, for example. A photo cell is turning the contactor on and off and the contactor is switching the load.
The reason for the contactor is, whatever is running the contactor, can't handle the load to be served and/or can't handle 2 circuits.
The 2 cables coming in on the left appear to be the line side, while the 2 on the right appear to be the load side. The one, top left, appears to be feeding the coil on the contactor.
Old 08-13-09, 07:08 AM
K
Hi wirenut1110,
Thanks for the information. There are some security system in the basement (Not in use right now). It could be the one that turns the contactor on and off. Since I am not using the security system, can I simply disconnect it? If so, which line or lines should I disconnect?
And you are right about the side. Left side is line and right is load.
Thanks!
Kevin
Old 08-13-09, 03:40 PM
W
Yes you can disconnect it.
If you're just concerned with the noise you can find the circuit that's feeding the coil (top left) turn it off and then disconnect the coil wire(s) and cap them(the ones with the spade connectors on them).
Keep in mind that there's several circuits run in there so even though you may turn that off, circuits will still be hot. (IF this is even high voltage)
I would leave everything there if you're not 100% sure what it's doing, it may go to something we don't know about yet.
Old 08-15-09, 07:36 PM
K
Thanks wirenut1110. Looks I have some home work to do
Old 08-16-09, 02:15 AM
F
Received 2 Votes on 2 Posts
Before you can disconnet follow the conductor to see where it goes first some case the contractor is used for both water heater and A/C compressor by using one leg of it to switch it on or off
so check it out first then decided what to do next and let us know what you find out.
Merci,Marc
