More out door power needed
Old 08-18-09, 03:53 PM
I have a existing GFI single gang on the outside wall.
I need to run power,( while keeping that box working )from that outlet to a new 2 gang ( 4 outlets for plugs ) and then from that new 2 gang to another single gang ( 2 outlets for plugs at the termanation point.
The existing outlet will have a Outdoor lite transformer, the new 2 gang will only be used periodically and the last single will have a small pump for a fountain.
Thanks in advance!
Hilby
Old 08-18-09, 04:10 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Welcome to the forums! What else is on the circuit of the GFCI? Or is it a dedicated circuit? Is it a flush mount receptacle or is it located in a WP box with a bubble cover? Sorry for the questions, but it helps us to know so we can go to the next step.
Old 08-18-09, 05:07 PM
Hi Chandler,
Hmmm, all i know is that on the inside of the house opposite the outlet of course, is a plug w/ a lamp plugged into it. So I'm thinking it's just for plugs. Right now on the outside it's flush mounted w/ a bubble cover. Would I need a new box w/ a hole at the bottom to attach the contuit to run the new wire? By the way the home is not yet 10 years old.
Thanks,
Hilby
Oh...and thanks for the welcome!
