Drilling Mistake
Drilling Mistake
I drilled to close to the stud's edge and have a little less than 1 1/4'' .
Can I glue a piece of dowel in the hole and re-drill a new hole through it ?
Thank you
Thank you
''Yeah, sounds like a job for nail plates.''
The side of the wall where the plate would be required is plaster/lath, the holes in the stud are close to the top and plaster crown moulding behind .No problem re-drilling
Thanks again
Thanks again
