Drilling Mistake
Old 08-21-09, 01:39 PM
R
Drilling Mistake
I drilled to close to the stud's edge and have a little less than 1 1/4'' .
Can I glue a piece of dowel in the hole and re-drill a new hole through it ?
Thank you
Old 08-21-09, 01:51 PM
W
Received 1 Vote on 1 Post
You can do that or just drill another a little higher or lower than that one and leave the oops alone.
Old 08-21-09, 01:59 PM
R
Thanks Wirenut .cant drill a litlle higher or lower as there are allready enough holes in that area and this a bearing wall
Old 08-21-09, 02:01 PM
I
Received 43 Votes on 41 Posts
Steel nailing plate it is.
Old 08-21-09, 02:04 PM
R
Why do you need to re-drill the hole? Put a steel plate infront of the hole on the face of the stud.
jim
Old 08-21-09, 02:12 PM
W
Yeah, sounds like a job for nail plates.
Now get back to work, I want this roughed in today....lolBeer 4U2
Old 08-21-09, 09:12 PM
R
''Yeah, sounds like a job for nail plates.''
The side of the wall where the plate would be required is plaster/lath, the holes in the stud are close to the top and plaster crown moulding behind .No problem re-drilling
Thanks again
