How much can a 15 amp breaker take?
Old 08-23-09, 04:00 PM
All the lights in the basement as well as my home theatre system currently run on this single 15 amp breaker. Would be able to also run 2 fridges on the same 15 amp circuit without it blowing?
Thanks
Old 08-23-09, 04:11 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You need to add up the amps of everything on it but two refrigerators would probably push it close to or over the limit.
Old 08-23-09, 05:08 PM
Most fridges pull at a minimum of 5.8 amps, some much more, so 2 of them on the same circuit with what you have already would be more than the breaker could take.
Old 08-24-09, 08:55 AM
Received 42 Votes on 40 Posts
I would recommend that you do not put the fridges on the same circuit as the home theater equipment.
