Installing double receptacles
Old 08-23-09, 06:35 PM
Question Installing double receptacles
I've installed single receptacles before, but not a quad/double. Is there anything special I need to know about wiring two sets of receptacles into one box?
Old 08-23-09, 07:09 PM
Tolyn Ironhand's Avatar
Received 54 Votes on 47 Posts
Nope. Black to brass. White to silver. Green to ground.
Old 08-23-09, 09:10 PM
most case useally noting specal with it it work the same as single recepale but just becarefull with the numbers of conductors in there if you see more than just two pair of conductors if that the case just make the pigtail for both of it and it will be easier to fold it back in the box.
otherwise it is straight foward task with it.
Merci,Marc
Old 08-24-09, 09:28 PM
Thanks guys, appreciate the input.
