Need help with Dimmer install...
Old 08-29-09, 09:00 AM
D
Greetings,
I'd like to replace a 3-way switch ( it controls the main floor hall lighting & is tied into the upstairs hall lighting ) with a dimmer switch. Do I need a special style dimmer to accomodate a 3-wire connection? Would I need to install a dimmer in the upstairs switch as well?
Thanks in advance!
Regards,
Dan
Old 08-29-09, 09:16 AM
I
Received 43 Votes on 41 Posts
You need to get a three-way dimmer, sometimes called a multi-location dimmer. You'll need to replace both switches with compatible multi-location units. When you pick out a dimmer, check the manufacturer's literature for information about what switches are compatible. Some will work with just a regular three-way toggle switch on the other end, but some require remote dimmers like the Lutron Maestro line.
Old 08-29-09, 12:25 PM
D
Thanks...
Job is done!
Appreciated,
Dan
Old 08-29-09, 12:48 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Good job. Thanks for letting us know how it came out.
