How to extend leads into Jbox?
Old 08-31-09, 07:50 AM
D
I am installing a fixture in an old house and needed to install a new Jbox. The problem is that the wiring leads do not quite make it long enough to go inside the box. How can i extend these without weakening the line?
Old 08-31-09, 07:56 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
If the leads won't reach you will need to install a second Jbox and extend new leads from there... That Jbox must remain accessible. If you can get an inch or so in the box you can splice on longer leads. Best (opinion) is to run new cable at least back to the last box before the short cable.
Old 08-31-09, 09:49 AM
Z
Received 106 Votes on 98 Posts
you can also sometimes shift the new box up or down a bit on the wall so the wires are long enough. It will require a bit of sheetrock patching, but it's often easier than re-running the wire.
