Intermatic Timer
Old 09-01-09, 07:57 AM
Handyone's Avatar
Intermatic Timer
I need to install an Intermatic Timer to control lights.
I'm working off memory so please forgive me, I don't have the timer here. However I believe the load side said 1000va.
Is this 1,000 watts total load?
Thanks Brian
Old 09-01-09, 08:04 AM
I
Received 43 Votes on 41 Posts
If you're controlling normal lights, then VA (volt-amps) is equal to watts. If you're controlling a motor, it's not always equal.
Old 09-01-09, 08:11 AM
Handyone's Avatar
Thanks
Yes, I'm controlling normal (or compact flourescent) lights.
And it is well under 1,000 watts. So should be good to go.
Thanks again
Old 09-01-09, 06:26 PM
Tolyn Ironhand's Avatar
Received 200 Votes on 178 Posts
Does this timer use a neutral? If not, it may not work with CFL's do to the leaking current to power the timer.
