Grounding in basement outlets
Old 09-03-09, 05:43 AM
T
I was hoping the community could provide some guidance. The outlets in my basement have 2 wires and no ground. Everything is run through metal conduit/boxes. The house was built in '94 and the outlets are NOG GFCI.
Do I have a grounding issue, or does the conduit act as my ground?
Thanks for the help.
Old 09-03-09, 07:01 AM
P
if the conduit runs all the way uninterupted to your supply box
then the conduit is acting as the ground. it`s still a good idea to run a ground wire, as conduit can lose conductivity, (corrode,come loose) over time.
Old 09-03-09, 07:46 AM
pcboss's Avatar
Received 83 Votes on 71 Posts
A bonding jumper should be run from the box to the green screw on the devices to ground them. The plastic or cardboard washers prevent a good ground path.
There should be a tapped hole in the back of the box where you would install a 10-32 ground screw with either a green or bare conductor sized to the circuit. You can buy premade grounding pigtails or you can make your own.
Old 09-03-09, 08:09 AM
T
Thank you both, I do appreciate the input. I have never seen a pre-made ground pigtail...is there any difference between that and just attaching a short piece of grounding wire from a screw in the back of the outlet box to the green screw on the outlet itself?
Old 09-03-09, 08:12 AM
pcboss's Avatar
The only difference is that the one is pre-made and is insulated. Typically they are only made with #12 wire. Functionally they are the same.
Old 09-03-09, 08:19 AM
T
So the insulation really doesn't make much of a difference?
Old 09-03-09, 08:24 AM
I
Received 43 Votes on 41 Posts
Not really no; it would prevent accidental shorting of the ground wire to a hot screw when you repack the box, but if you fold the wires in carefully it's not an issue anyway. The premade ones are really for convenience and speed of installation.
