Arc Fault CB-?? Neutral
Old 09-03-09, 05:13 PM
B
Installing arc fault cb and the neutral doesn't reach the other side if the CB box.
Is it legal to pigtail an extended neutral in the box??
I dont want to reconfigure the panel to accomodate installation.
Thanks
BobH
Old 09-03-09, 06:06 PM
Z
Received 103 Votes on 96 Posts
Absolutely. The panel is just like any other box, go ahead and add a pigtail and wire nut to extend your neutral.
Of course, make sure you use a white wire and a wire of the same (or larger) gauge.
Old 09-05-09, 05:08 AM
B
thanks alot for the response and thanks to DIY for the forum
BobHud
