1/3 hp 120v: starts sometimes and more
Old 09-04-09, 10:14 AM
Bought this at a yard sale and probably overpaid: I reversed the direction, no problem. Motor starts, sometimes, sometimes not - just hums, AND sometime in the WRONG direction. When it does not start I can turn the shaft to start it. BUT I can get it to run in either direction???
Someone tell me there is an easy solution!
Stephen
Old 09-04-09, 11:12 AM
I
Received 43 Votes on 41 Posts
Replacement of the start capacitor would probably fix it up. Go to a motor shop and get a capacitor that is of equal or higher voltage rating and equal or higher capacitance but not more than about 15% higher. Of course a good cleaning and lube of the bearings can't hurt either.
Old 09-04-09, 11:22 AM
Thanks, but. . .
I had motor apart. Did not see capacitor. Did see a centrifugal switch (I think that's it) which was sticking a little. Cleaned as best I could - much better, but still probs.
Any other possibilities?
Old 09-04-09, 01:34 PM
Went back into the motor and found a wire not connected to antything. Made a good guess to where it was supposed to go, re-attached the wire and the motor works!
Stephen
Old 09-04-09, 01:49 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Glad you got it. Thanks for letting us know.
